Проблемы при сопоставлении товаров
isbesedin
Для одного из поставщиков при попытки сопоставить товары вываливается ошибка:
{ "readyState": 4, "responseText": "Notice: Error: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'мембрана\" цв. Серый Лес Снегоза' at line 45
Error No: 1064
SELECT p.*, IF(p.supply_product_id>0, 1, 0) as flag_found, pd.name, pd.description_short, pd.description_full, pd.meta_description,
error: SyntaxError: Unexpected token < in JSON at position 0
Попробуйте сейчас.
isbesedin
Ничего не изменилось.
Для примера брался костюм Памир. Набираю в поиске памир, вываливается:
{ "readyState": 4, "responseText": "Notice: Error: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'мембрана\" цв. Белый Лес (ветки) ' at line 45
Error No: 1064
SELECT p.*, IF(p.supply_product_id>0, 1, 0) as flag_found, pd.name, pd.description_short, pd.description_full, pd.meta_description, pd.meta_keyword, pd.meta_title, pd.seo_h1, pd.tag, \n\t\t\t\t\t\t\tpi.image, \n\t\t\t\t\t\t\tpi.image_original,\n\t\t\t\t\t\t\tpi.image_cloud_url,\n\t\t\t\t\t\t\turl_alias_category.keyword as seo_url_category, \n\t\t\t\t\t\t\turl_alias_product.keyword as seo_url_product, \n\t\t\t\t\t\t\tpc.name as supply_name, \n\t\t\t\t\t\t\tcg.name as contractor_group_name,\n\t\t\t\t\t\t\tcd.name_full as category_name_full, \n\t\t\t\t\t\t\tcd.addon_text as category_addon_text, \n\t\t\t\t\t\t\tssd.name as stock_status_name, \n\t\t\t\t\t\t\tss.color as stock_status_color, \n\t\t\t\t\t\t\tss.image as stock_status_image, \n\t\t\t\t\t\t\tss.image_cloud_url as stock_status_image_cloud_url, \n\t\t\t\t\t\t\tm.name as manufacturer_name, \n\t\t\t\t\t\t\t'RUB' as currency_code, \n\t\t\t\t\t\t\tIF(warranty_cd.unit<>'', warranty_cd.unit, warranty_cd.title) as warranty_unit, \n\t\t\t\t\t\t\tweight_cd.unit as weight_unit, \n\t\t\t\t\t\t\tlength_cd.unit as length_unit, \n\t\t\t\t\t\t\t( IF (REPLACE(pd.name, ' ', '') LIKE '%к_м_ПАМИР_тк_алова__мембрана__цв_Белый_Лес_ветки_Снегозащитные_гетры%', 120, 0) + IF ( m.name LIKE '%Huntsman%', 80, 0) + IF ( p.mpn = 'к-м ПАМИР тк. алова-\"мембрана\" цв. Белый Лес (ветки) Снегозащитные гетры!!!', 1000, 0) + IF ( p.mpn LIKE '%к-м ПАМИР тк. алова-\"мембрана\" цв. Белый Лес (ветки) Снегозащитные гетры!!!%', 400, 0) + IF ( REPLACE(pd.name, ' ', '') LIKE '%к-м ПАМИР тк. алова-\"мембрана\" цв. Белый Лес (ветки) Снегозащитные гетры!!!%', 40, 0) + IF ( p.mpn LIKE '%к-м ПАМИР тк. алова-\"мембрана\" цв. Белый Лес (ветки) Снегозащитные гетры%', 20, 0) + IF ( REPLACE(pd.name, ' ', '') LIKE '%к-м ПАМИР тк. алова-\"мембрана\" цв. Белый Лес (ветки) Снегозащитные гетры%', 30, 0)+ IF (REPLACE(pd.name, ' ', '') LIKE '%ПАМИР%', 2, 0)+ IF (REPLACE(pd.name, ' ', '') LIKE '%тк%', 2, 0)+ IF (REPLACE(pd.name, ' ', '') LIKE '%алова%', 2, 0)+ IF (REPLACE(pd.name, ' ', '') LIKE '%мембра%', 2, 0)+ IF (REPLACE(pd.name, ' ', '') LIKE '%цв%', 2, 0)+ IF (REPLACE(pd.name, ' ', '') LIKE '%Белый%', 2, 0)+ IF (REPLACE(pd.name, ' ', '') LIKE '%Лес%', 2, 0)+ IF (REPLACE(pd.n\":0,\"Rows\":[]}]", "status": 200, "statusText": "OK" }
Доработали, попробуйте сейчас.
isbesedin
Теперь работает, спасибо.
