При входе в "Базовый каталог товаров отображается это"
Notice: Error: The used SELECT statements have a different number of columns
Error No: 1222
SELECT 'grid_product' as grid_code, 'Товар БК' as grid_name, 2 as grid_id, 2 as group_id, 'pa.' as field_table_prefix, '' as datafield_source, CONCAT('attribute_', a.attribute_id) as datafield, '' as datafield_expression, (a.sort_order+500) as sort_order, 'string' as datafield_type, '' as datafield_format, '' as columntype, 0 as is_required, 1 as is_visible, 0 as is_system, 0 as hidden, 1 as editable, 1 as filterable, 0 as sortable, 0 as exportable, '' as cellsalign, '' as align, '100' as width, '' as cellsformat, 'cell_format_product' as cellsrenderer, 'cellclassname_product' as cellclassname, 'columnsrenderer_product' as renderer, 'textbox' as filtertype, 'contains' as filtercondition, 0 as pinned, 0 as show_on_panel, 1 as show_header, '2018-02-13 11:12:09' as date_added, '0000-00-00 00:00:00' as date_modified, 1 as user_id, a.uuid, a.attribute_id, 'attribute' as grid_sub_code, '' as columngroup, '#1c84be' as column_fore_color, '' as column_back_color, REPLACE(ad.name, '"', "'") as grid_field_name, -1 as field_is_system, '' as price_field_code, '' as price_column, 1 as status_show, 1 as status_edit, 0 as field_is_formula, '' as is_sort FROM et_attribute a ORDER BY sort_order in setting.php on line 1421
Не работает, в прицнипе, ничего
Notice: Error: The used SELECT statements have a different number of columns Error No: 1222
Попробуйте сейчас.
